Transparency
maneavel
Transparency
Post by maneavel »
I'm using nconvert to convert PNG to JPG using this lign of command : xnview -npcd 2 -size 256x256+0 -ctype rgb -corder inter -out jpeg -o C:\Images450\%%.jpg -autocrop 0 255 255 255 -ratio -rtype lanczos -rflag orient -resize 450 450 -bgcolor 255 255 255 -canvas 450 450 center "C:\Users\PPMC-Julien\Desktop\base\ChouChous-Minis-carreaux-amande-164908.jpg"
When i use xNview : no problem.
But when i use nconver i got this kind of result :
Do you know what i'm doing wrong?
Thank you for you help!!
there's the original :
Re: Transparency
Please use -merge_alpha if you don't save alpha channel
maneavel
Re: Transparency
Post by maneavel »
Works perfectly, thanks Pierre.
asabled
Re: Transparency
Post by asabled »
Hello
I have a similar problem while trying to convert transparent png to to transparent tiff.
I would like to keep the transparency but I get strange results
Here is a screenshot
http://cjoint.com/?0Icbjes9Oqh
The command line used is
Thank for your help
Re: Transparency
asabled wrote:Hello
could you send me your file?
