XnView installation fails can't register dll)
rudio
Post by rudio »
I tried to install XnView 2.10 extended on my PC (Windows7 home premium 64bit), but I had to cancel the process due to one or more error messages like this one:
I tried to install in administrator mode, tested the "SageThumbs" trick, but nothing worked. What can I do to update the existing version successfully?
tnx Rudi
Re: XnView installation fails can't register dll)
there is no image. If you try ignore?
DOS386
Post by DOS386 »
"Xbmf.dll"
1. Make sure the existing XN version is NOT running.
2. Make sure no other program blocks this file (virii/antivirii)
3. Delete the old installation manually directory "XnView" or "PlugIns" at least
4. Use the ZIP
rudio
Post by rudio »
xnview wrote:there is no image. If you try ignore?
Dear Pierre,
strange behaviour: I can see the picture, if I'm logged into the forum. If I log out, it disappears ... ?
rudio
Post by rudio »
DOS386 wrote:"Xbmf.dll"
4. Use the ZIP
Thanks for this tip. I'll try this soon and report the result.
cheers Rudi
rudio
Re: XnView installation fails can't register dll) - SOLVED !
Post by rudio »
Hi all,
the brandnew XNView v2.11 installed itself perfectly, at least in administrator mode. No special measures like deactivation of AV software, were taken.
thanks anyhow
Rudi
