Batch Resize to constant width or constant height
dietmar
Post by dietmar »
Pierre,
if I understood the batch resize options correctly, there are four options (and the Mega-Pixel):
- Resize to fit into X*Y box
- Resize to fill at least X*Y box
- Resize larger side to X
- Resize smaller side to X
From a user's point of view it would be nice to have separate options for
- Resize width to X (this is the same as Resize to fit into X*9999999)
- Resize height to X (likewise this equals Resize to fit into 9999999*X)
Dietmar
Re: Batch Resize to constant width or constant height
You can do that by settings other dimension to 0
