0.68 mac: filter by rate is not effect
It is the same as All what the effect of choosing Poor, Fair, Average, Good and Excellent. but only Unrated is right.
Re: 0.68 mac: filter by rate is not effect
Do you mean that filtering by Rating doesn't work? Can you explain in more words what the problem is? Ideally, is best to write down some steps to reproduce (1. 2. 3....) and what is the Expected effect by you and what is the Actual action which program does instead.
Do you have some photos Rated before?
m. Th.
Yes, it seems doesn't work fine.
I have some photos and rated them with Average or Good or Excellent(Poor or Fair photos was deleted), after that, I choose a filter option, eg. Good, but the action have not effect, there are all photos, includes all rated photos and Unrateds. like choose filter by All. only when I choose Unrated, there are only Unrated.
example:
1, There are four photos be rated: Average, Good, Excellent and Unrated
2, Choosing filter by Unrated, It will only show one photo which be unrated, that is right
3, Choosing filter by Good, I think it will only show one photo which be rated Good, but now show all four photos, it seems a bug
4, Choosing filter by Average or Excellent, it is the same as choosing Good
Sorry for my english, hope you could understand
example:
which filter do you use? could you post a screenshot?
raptorz wrote:Yes, it seems doesn't work fine.
example:
Yes, we understand. However, I cannot reproduce. Besides what Pierre said (pls answer him) let me ask you something else:
In the Filter Drop-down menu which operator did you chose (which one is highlighted)?
The operators are marked with a green circle in the screenshot bellow:
In order to work as you want, you need to select the "=" (equal) operator like in the picture above.
m. Th.
It seems something different. There is not operators to choose.
You could see the filter result in screenshot too.
- Attachments
- 屏幕快照 2014-05-29 下午11.15.28.png (131.48 KiB) Viewed 2265 times
Mac. Hummm....
I don't have experience with XnView on Mac. But perhaps Pierre will help us....
m. Th.
ok, i confirm the bug
See Issue 391 for current status and details.
Thank you. waiting for the new version.
Hello. Do you know if this change was implemented in 1.0 for Mac OS? I don't seem to have this option. Mine looks similar to the previous screenshot.
Thank you.
Thank you.
