0.68 thumbnails turned for .nef files
TD
Post by TD »
When I use
View | Update database from files
for one or more .NEF files with potrait orientation, the thumbnails of these files are sometimes turned 90° to the right.
Regards,
m.Th.
Re: 0.68 thumbnails turned for .nef files
Post by m.Th. »
Which version do you use?
32 or 64 bit?
m. Th.
TD
Post by TD »
32 bit Windows XP and 64 bit Xubuntu 14.04
Same behavior with both installations
please send me a nef file?
TD
Post by TD »
I could send you nef files but, in the meantime things got more complicated. Under Linux now the thumbnails are no longer turned (and I don't know what I changed) but under Windows they are still turned.
So I think it is not really a matter of my files. If you want one anyway, no problem.
Regards,
you can try to rename xnview.ini
TD
Post by TD »
xnview wrote:you can try to rename xnview.ini
Did that and the problem is gone. Thank you!
