Different setting for display of Camera RAW in Preview
cassowarry
Post by cassowarry »
In XnView it was possible to assign different values for display of Camera RAW images in View and Browser-Preview. In XnViewMP it is only possible to select the type for display of Camera RAW in View. For the browser preview the same type is used.
When I want to see images in the viewer in full resolution, the preview in the browser is also in full resolution. Meaning I have to wait about 5 seconds when browsing from image to image. When I select "Embedded preview" the browsing of images is quite fast, but when I look at the image in the viewer I only see the low resolution embedded preview.
Could you please introduce the same handling like in XnView, so I can see in the browser preview the "Embedded preview" and in the viewer the full resolution RAW image?
Re: Different setting for display of Camera RAW in Preview
ok, having 2 settings can be confusing...
m.Th.
Post by m.Th. »
Actually we have all 3 (three)! :)
We have one (and we must have it) in Batch Convert.
We have another general one (and we must have it) in Tools | Settings etc.
And the one which cassowarry search is in Viewer|Editor's menu: Go To File | Format Settings... and go to Read tab - here you must change the Camera RAW's tab 'Use' drop-down box to your desired value.
m. Th.
not this one, view>Camera RAW
m.Th.
Post by m.Th. »
Yes, I figured this after. :(
Too bad.
m. Th.
cassowarry
m.Th. wrote:Actually we have all 3 (three)! :)
No! It seems there are only 2!
The one in Tools | Settings | View > Camera RAW and in the viewer in File | Format Settings > Camera RAW are the same. You can change either one and the result will always be that the preview in the browser shows the same size. What I'm talking about is the same pssibilities like in XnView.
One setting for the viewer (like there is already):
And another setting for the preview in the browser (which should come):
This would really be nice!
