Fullscreen: "Quit" closes program!
orbspider
Post by orbspider »
When I launch fullscreen from browser, I would expect the only option on right-click menu would be quit fullscreen and return to browser.
But Quit closes XnView!
The top button "Fullscreen" ironically closes fullscreen and returns to browser.
Fine, I know what Fullscreen F11 does, and I normally use Enter again or escape anyway. But perhaps Quit shouldn't be on the menu? it can catch a user out.
Re: fullscreen Quit option closes program!
yes ESC or F11 quit the fullscreen
orbspider
Post by orbspider »
indeed, yes, but Quit on the menu might end some one's XnView session when they only wanted to close the fullscreen.
orbspider wrote:indeed, yes, but Quit on the menu might end some one's XnView session when they only wanted to close the fullscreen.
Problem still not fixed in v0.84.
Actual behaviour (bug): In context menu of Viewer the last entry is "Quit". :bug:
Expected behaviour: In context menu of Viewer the last menu item is "Close" (to close the fullscreen). There's no menu item "Quit" in the context menu.
:arrow: Reproduced
Re: Fullscreen: "Quit" closes program!
O.k., thank you, I can also reproduce the problem. Issue 1232 is fixed in next version.
This problem is supposed to be fixed in XnView MP 0.87. Please check and confirm the bug fix here.
HanVroon
Post by HanVroon »
Tested in 0.87 beta 2, fixed.
Like in another bug report about View mode, now in View mode and Fullscreen mode the context menu option "Quit" is replaced by "Close", so the program isn't closed but the (fullscreen)view is closed.
