I can think of two possible extension options:
- trim from selected frames only (top, bottom, left, right)
- trim when pattern changes (rather than detecting first if pixels adjacent to the frame have the same color and then detecting how wide the same area towards the centre is - this would be detecting just the break in the pattern so therefore could support multiple different colors initially adjacent to the frame. For instance, image:
RRRRRGGGRRRRRRRR
RRRRRGGGRRRRRRRR
RRRRRGGGRRRRRRRR
RRRRBGGRRRRRRRRR
RRRRBGGRRRRRRRRR
RRRBBBGGRRRRRRRR
RRBBBGGGGRGRRRRR
RBBBBBBRRRRRRRRRCode: Select all
RRRRBGGRRRRRRRRR
RRRRBGGRRRRRRRRR
RRRBBBGGRRRRRRRR
RRBBBGGGGRGRRRRR
RBBBBBBRRRRRRRRRand in:
RRBBBGGRRR
RBBBGGGGRG
BBBBBBRRRRwhereas default trim (like in IrfanView) would result in:
RRRRGGGRRR
RRRRGGGRRR
RRRRGGGRRR
RRRBGGRRRR
RRRBGGRRRR
RRBBBGGRRR
RBBBGGGGRG
BBBBBBRRRR
