how about impllmenting such a MOD into this forum
http://www.phpbb.com/phpBB/viewtopic.php?t=207960
Forum suggestion: Highlight Topics User Posted In
XNView 1.91.5
Windows XP SP3
Windows XP SP3
Re: Forum suggestion: Highlight Topics User Posted In
1) Because it doesn't come as an EasyMod-extension (better & safer installationklumy wrote:Hi,
2) Because the thread posted shows lots of problem that might arise upon installation.
The fact is, that phpbb caused lots of problems in the past (this board was hit by several attacks) so I'm not willing to spend hours and hours of trial-and-error searching for possible installation problems, patching files manually with different mods and so on, only to discovery another security hole has been opened; sorry for that ,-))
On the other hand, if you find a mod that can be installed using EasyMod and shows no installation problems we can talk about ,-)
Best regards,
Soeren
Thanks, klumy for suggesting, but as Sören has pointed out already, we will only apply Easy Mods on this phpBB forum. The Easy Mods are Mods which install easily (without manually changing phpBB code).klumy wrote:Hi,
