I have an image of the hard disk loaded and modified (size and colors).
With STRG-A I marked the whole picture and copied it with STRG-C to the clipboard.
If I insert the modified image from the cliboard into another program, only the stored image will appear.
All changes to the image are ignored.
Please fix it!
Clipboard function uses the image stored last. - Versio 0.79
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
Re: Clipboard function uses the image stored last. - Versio
i can't reproduce, i have the modified one in clipboard
I tested it again.
Different picture programs import the picture from clipboard in the correct size.
Only Microsoft Word 2016 can not import the image with the modified size and other modifications.
That is stupid!
That is stupid!
which software do you have tried?masterjp wrote:I tested it again.
That is stupid!
Microsoft Word is the problem.
I pasted the resized picture from clipboard in Word 2016 and then I got the wrong picture size.
In a microsoft word forum I read an article, that you must use paste special in word to get the picture with the correct size.
i think that MS use the filename copied in clipboard and not the image data!
masterjp wrote:Microsoft Word is the problem. ....
