0.84: Status bar not updated with 1st file at beginning
m.Th.
Post by m.Th. »
Upon entering in the folder the 1st file is selected but the status bar isn't updated with the details of the 1st file.
m. Th.
Re: 0.84: Status bar not updated with 1st file at beginning
I can confirm this problem.
:arrow: Reproduced
Notes:
- Setting "Select first item on entering folder" in Settings: Browser » File list » Show hidden files & folders must be checked.
- To see the problem the first file must be an image file (folders don't matter)
- One can see the missing information when clicking on the first file after navigating to the folder.
O.k., thank you, I can also reproduce the problem. Issue 1225 is fixed in next version.
This problem is supposed to be fixed in XnView MP 0.87. Please check and confirm the bug fix here.
HanVroon
Post by HanVroon »
Fixed.
Same bug as:
http://newsgroup.xnview.com/viewtopic.php?f=111&t=30474
"0.68: Info in statusbar incomplete when entering folder"
