0.85b2: Renaming file/folder in use issues
Dreamer
Post by Dreamer »
XnView: MP 0.85 beta 2 - 64-bit and MP 0.84 - 64-bit
OS: Windows 10 - 64-bit
1. Enter the folder with at least 1 video file
2. Open this video file in associated program (e.g. VLC)
3. In MP go up and try to rename this folder
Actual behaviour (bug): Folder is not renamed, without error dialog :bug: 1
Expected behaviour: Error dialog that folder is in use should be displayed.
1. Enter the folder with non image file (e.g. video or chm)
2. Open this file in associated program (file must be in use)
3. In MP try to rename the file
Actual behaviour (bug?): MP "Replace" dialog is displayed instead of "file in use" error dialog :bug: 2?
4. Click the "Rename" button (while the "New name" field contains the text "Copy of")
Actual behaviour (bug): File is not renamed, because it's in use. Without error dialog. :bug: 3
Dreamer
Re: 0.85b2: Renaming file/folder in use issues
I confirm all the above bugs. From my point of view bug #3 is a subsequent error.
:arrow: Reproduced
arspr
Post by arspr »
And yet another possible variant: XnView seems to conflict with itself when renaming a video from Fullscreen. But it works fine with images.
O.k., thank you, I can also reproduce the problem. Issue 1269 is fixed in next version.
This problem is supposed to be fixed in XnView MP 0.87. Please check and confirm the bug fix here.
Dreamer
Post by Dreamer »
Fixed in 0.87 beta 1, thanks, Pierre.
:arrow: Closed.
Dreamer
