0.84: Thumbnails+filenames view: Filename truncated
phaolo
Post by phaolo »
XnView: MP 0.84 - 64 bit
OS: Windows 7 - 64bit
Browser mode, file "View as" "Thumbnails+filenames" problem:
long filenames become unreadable, because the label text is centered, instead of being aligned left or wrapped.
Effect: real name difficult to read in the list.
1- create a long filename.
2- select the view and look lol.
Actual behaviour (bug): label text is centered :bug:
Expected behaviour: label text aligned left or wrapped.
m.Th.
Re: 0.84: Thumbnails+filenames view problem
Post by m.Th. »
For me, the text is left aligned (even if it has indeed some glitches) when it is bigger than thumb's width both for folders & images. Tested in 0.84 and 0.85b2:
Long titles.jpg (9.19 KiB) Viewed 2086 times
Perhaps we missing something?
Try to resize the thumbs. It works now?
m. Th.
Right, m.Th., two screenshots and/or a screen video capture would be good to understand the problem.
(The first letter is partly truncated; this should be fixed).
phaolo
Post by phaolo »
helmut wrote:The first letter is partly truncated; this should be fixed.
Ah ops.. maybe that gave me the impression of the text being centered.
Sometimes the first letter is completely cut out (e.g: i,l,t,r) or can't be recognized (o,b).
It seems to happen randomly with long names, though. O_o
phaolo wrote:...Sometimes the first letter is completely cut out (e.g: i,l,t,r) or can't be recognized (o,b).
O.k.. m.Th. and I both confirm the problem with the first letter truncated.
:arrow: Reproduced
Re: 0.84: Thumbnails+filenames view: Filename truncated
O.k., thank you, I can also reproduce the problem. Issue 1208 is fixed in next version.
This problem is supposed to be fixed in XnView MP 0.87. Please check and confirm the bug fix here.
HanVroon
Post by HanVroon »
Tested with 0.87 beta 2, seems fixed.
Could reproduce the bug with 0.86 and a lof filenamen starting with "A".
Only went wrong with View as Thumbnail + filename.
Could not reproduce the bug anymore in 0.87 beta 2.
