0.85b4: Custom order - minor sorting issue in Details view
Dreamer
Post by Dreamer »
XnView: MP 0.84 - 64 bit and 0.85 beta 4 64 bit
OS: Windows 10 - 64bit
1. Sort items by Name
2. Switch to Details view
3. Drag any file(s) in the middle of the list, to make a custom order
4. You can double click the parent folder to go up and then go back to previous folder
5. Click the Sort by sub-button ([v])
Actual behaviour (bug): There's a sign next to the Name, so it looks the items are sorted by name, but custom sorting is active (correctly in the Sort by context menu). :bug:
Expected behaviour: Sign next to the Name should be removed if custom order is activated.
Dreamer
arspr
Re: 0.85b4: Custom order - minor sorting issue in Details vi
Post by arspr »
Yes, I can confirm the issue.
You don't even need to exit and re-enter that folder. When you create a custom order the "v" or "^" symbol is maintained in the original column although the file list is not sorted by that column anymore.
See the attached image where you can see the "^" icon on Name column heading but the list actually has a custom order.
Dreamer
Post by Dreamer »
Thanks for confirming the issue.
arspr wrote:You don't even need to exit and re-enter that folder.
Right, it was just to show that changing folder doesn't fix it. So the step 4 is not needed.
XnView restart fix this issue.
Dreamer
do you have always the issue with lastest version, i can't reproduce
arspr
Re: 0.85b4: Custom order - minor sorting issue in Details view
Post by arspr »
I've just retested with 0.86 and the problem is there (at least on W10).
Look at the attached screenshot. (The first file is out of alphabetic order but you can see the "^" sign in Name column heading).
It doesn't matter if I exit and re-enter that folder. The bug is there.
But if I press F5, the bug is gone. I mean the "^" disappears from the Name column heading.
Just retested on 0.86 - The bug is there
arspr wrote:I've just retested with 0.86 and the problem is there (at least on W10).
So the issue is that the "^" sign in header is not removed after custom sort?
arspr
Post by arspr »
Yes, that's it. The interface is telling the user a Name sorting is active when in fact there's a custom order. Name sorting (or whichever other one) is not active any more.
More over, a F5 refresh does actually solve it.
O.k., thank you, I can also reproduce the problem. Issue 1272 is fixed in next version.
This problem is supposed to be fixed in XnView MP 0.87. Please check and confirm the bug fix here.
Dreamer
Post by Dreamer »
Fixed in beta 1, thanks, Pierre.
:arrow: Closed.
Dreamer
