- Make sure that the 'Only one instance' option is checked
- Open any image in to view mode
- Then open the 'Effects...' dialog or any other dialog what haves that 'Apply to image' checkbox. (Don't close the dialog)
- Open any image to XnView from Windows explorer. Open file to associated to xnview or use the send to menu or whatever way you prefer to open files.
= XnView crash!
Windows 2000
XnView 1.80.3
I am not sure if this happens only with dialogs what haves that 'Apply to image' checkbox, but it sure feels like it.
