command line printing
Gallego
Post by Gallego »
Hello together,
I've seen it have been asked several times in the past. Yungest is near one year old and unfortunately I couldn't identify the version they was usuing.
Mine is 1.80.3 Is it possible to print a tif-file over the comand line? May be using some of the nice parameters as:
- putting special text into each frame
- adapt picturesize to papersize
I've yes (what I hope) where can I find the syntax
THX 4 the reply
Regards ex Germany
Felix
Re: command line printing
Gallego wrote:Hello together,
You can use -print, but it's not possible to add text, or specify special option
opalschleifer
-print comand line option
Post by opalschleifer »
is it possible that the -print commandline option no longer works in the current version? Or will I have to do some cutomization first?
Thanks for your help,
Thomas
Re: -print comand line option
opalschleifer wrote:is it possible that the -print commandline option no longer works in the current version? Or will I have to do some cutomization first?
No, but don't work??
