Option "After 'Save as' change filename"
I think by default, the option "After 'Save as' change filename' should be active (Tools > Options, category "General").
Currently, the filename is kept after 'Save as..' which I find irritating.
Logical, I agree.
• Hi !
- I agree. I tick that box always here.
- Aside, I wonder to know if the displayed image is really the “Saved as…” one.
- According to my daily use, it seems that the source-file you “Saved as…” is still displayed in «View», not the picture converted in the new format… ?
:mrgreen: G
Re: Option "After 'Save as' change filename"
helmut wrote:I think by default, the option "After 'Save as' change filename' should be active (Tools > Options, category "General").
Everyone agrees?
ckv
Post by ckv »
I agree, but far as I know, when this option is on and you save example a bmp to jpg the filename changes, but the actual file isn't updated (The same bmp remains and the jpg isn't loaded). This is good in some cases, but there should be a option to load the saved file.
Edit: Oh Clo seems to have pointed this out already.
I'll make a new requests about this.
