0.96.2 - Issue moving a category by drag&drop
Gwenael Q.
Post by Gwenael Q. »
Issue : Moving a category by drag&drop can lead to two categories with the same name side-by-side (for a while)
1. In the Categories pane (View > Data pane > Categories), create a category "Testing" then a subcategory "Categ1"
2. Create, elsewhere, a category "Categ1" then drag&drop it into "Testing" . The pane now displays two categories "Categ1" side by side within "Testing" category.
3. Close and reopen XnviewMP : the moved category is back to it's previous position.
Expected behavior
XnviewMP should not allow to drag&drop a category where it can not be moved.
I suppose that by design two categories with the same name can not share the same "path".
XnViewMP 0.96.2 - 64 bit on Windows 8.1 64bit
Thank you for listening
Re: 0.96.2 - Issue moving a category by drag&drop
Gwenael Q.
Hello
Fixed.
Tested with MP 1.4.0
Thanks for the good job !
