Something I find useful to help to adjust timestamp with "Change timestamp" is to take a photograph of my watch after having noticed that local time zone of the camara was not correctly set and compare the watch image and "new" timestamp while changing the value of the temporal shift.
But this tool is quite often used with a batch of image and it is very tedious to select the last image of a large selection with the "next button".
Request : Please consider adding "last" (and "first") button and/or allow edit of the filename of the displayed image in the "Change timestamp" interface.
Thank you for listening.
0.96.3 x64 on windows 8.1 x64
"Change timestamp" small UI improvement request
Re: "Change timestamp" small UI improvement request
This problem is supposed to be fixed in XnView MP 0.96.5. Please check and confirm the bug fix here.
"Last" and "first" buttons added.
Thank you for the improvement !
Version 0.96.5 64bits (Aug 17 2020)
