Hide/show hidden files button
MARK2580
Post by MARK2580 »
Make a button for the bar that will enable or disable the display of hidden files. It is not convenient to go into the settings every time and look for this option. Well, or at least a hotkey. :D
Re: Hide/show hidden files button
you're right
MARK2580
Post by MARK2580 »
Any news on the implementation of this feature? I still don't see such a button in the settings. :?:
MARK2580
Post by MARK2580 »
xnview wrote: Thu Feb 24, 2022 10:05 am See issue for current status and some details.
Did I wait. Looking forward to the new version. :D
MARK2580
Post by MARK2580 »
xnview wrote: Mon Mar 28, 2022 10:20 am This problem is supposed to be fixed in XnView MP 1.00 beta. Please check and confirm the bug fix here.
Fine ! Thanks a lot. Now it will be much more convenient. :D
UPD: It seems I noticed a bug, if the display of hidden files is disabled, but you are in some hidden folder (for example, from your favorites), then there is no activity in the folder tree, the cursor remains in place.
If you enable the display of hidden files, using a new button or in the settings, the folder tree also remains inactive, only restarting the program with the display of hidden files ON helps.
