1. select more than one picture in browser
2. press ctrl+i to edit IPTC data
3. change to tab date / time
4. use button >> to get context menu
5. and choose exif date taken/digitized
-> xnview crashes
b1: set IPTC-date to EXIF-date for multiple pictures
no crash
now xnview doesn't crash any more -
but one question (I'm not sure whether this is a bug or request):
If you choose "Write" - then only one picture will be modified.
If you choose "Write All" - then all picture will be modified and have the SAME date/time.
Maybe that's correct, but I think it should work like a batch job and each IPTC- data/time fields should get his own value from EXIF values.
Re: no crash
Yes, currently this value is not taken from each fileDirk wrote:now xnview doesn't crash any more -![]()
Re: request
OK, moved to "Closed..." (with shadow).
I can't split a single post and also this is not very clear...
Dirk, please start a new topic for this. Thanks.Dirk wrote:...But the user handling is not very good for 100 and more pictures...
