0.99.1: Zooming out does not work with small zoom steps
HumanEntity
Post by HumanEntity »
XnView: MP 0.99.1 - 64 bit
OS: Windows 10
XnView MP refuses to zoom out when the relative zoom steps is set to a small number.
Effect: You can still zoom in, but you cannot zoom out.
1. Change 'Zoom step' to 'Relative step'
2. Set the stepping size to 1.01000000
3. Zoom in on any image. You will be unable to zoom out after zooming in.
Image of settings for clarity:
Zoom settings.png (4.68 KiB) Viewed 15774 times
______________________________________________________
Actual behaviour (bug): Can no longer zoom out after zooming in.
Expected behaviour: Still being able to zoom out.
The threshold seems to be 1.15 or so. Any decimal lower than that, and the bug starts appearing. Entering e.g. '1' works fine.
Re: 0.99.1: Zooming out does not work with small zoom steps
HumanEntity
Thank you! :)
I am looking forward to the next version.
Have a good day!
HumanEntity
I downloaded the beta, but it's very broken now: XnViewMP now zooms in a lot always, regardless of my relative zoom-step settings.
HumanEntity wrote: Sun Apr 03, 2022 9:53 pm I downloaded the beta, but it's very broken now: XnViewMP now zooms in a lot always, regardless of my relative zoom-step settings.
right, will be fixed
Please check Beta 2
HumanEntity
Thanks. I am not quite sure if it properly honors numbers like 1.01 OR 1.009 (numbers below 1%?) but at least it doesn't get stuck anymore now! That's a lot better.
