0.99.4 Can't copy files after renaming it
hue
Post by hue »
XnView: MP 0.99.4 - 64-bit
OS: Windows 10 - 64-bit
XnView can't copy files after renaming it.
1. Open any image file with XnView.
2. Click File - Browse
3. Rename the file (right click - Rename)
4. Copy the file (Ctrl+C or right click - Copy)
5. Open Windows File Explorer
6. Go to different folder location and try to paste (right click - paste)
7. Nothing happens.
Actual behaviour (bug): XnView can't copy the file after renaming it.
Expected behaviour:
In previous XnView version, I can immediately copy files after renaming it. When I open Windows File Explorer and paste it, the file should get copied.
Re: 0.99.4 Can't copy files after renaming it
i can't reproduce, you can every time?
hue
Post by hue »
xnview wrote: Sun Dec 05, 2021 10:19 am i can't reproduce, you can every time?
Yes, I can.
I found out that I'm getting different result depending on how I start XnViewMP.
If I open XnViewMP from Start Menu or Desktop, I can do the rename + copy operation just fine.
But if I start XnViewMP by opening an image from Windows File Explorer, the above problem happens.
hue
Post by hue »
Here are the screen recording:
1. starting XnViewMP by opening it from desktop
Result: file successfully copied because XnViewMP copied the entire file path correctly.
2. starting XnViewMP by opening an image from Windows File Explorer
Result: unable to copy the file because XnViewMP only copy the file name, without the path.
This problem is supposed to be fixed in XnView MP 0.99.5. Please check and confirm the bug fix here.
hue
Post by hue »
xnview wrote: Thu Dec 09, 2021 2:00 pm This problem is supposed to be fixed in XnView MP 0.99.5. Please check and confirm the bug fix here.
Confirmed, it is fixed. Thanks!
