XnViewMP 0.99.4 - JPEG Export-Dialog - Compression - Invalid values may be entered
masterjp
Post by masterjp »
First thank you for the latest release. It is fantastic to see the solved bugs and new features! Wonderful.
The JPEG XL export dialog let the user set a compression value from 0 to 99.
I think the setting is for JPEG XL 'effort' parameter, which allow values from 0 to 9. Please limit the possible values.
Higher values than 9 are not accepted by the JPEG XL encoder and than it uses the default value.
Furthermore it would be great, if you can update the JPEG XL library with version 0.61, because there are speed improvements for some compression levels and bug fixes. Sometimes I think the memory usage for encoding/decoding is a bit lower.
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
Re: XnViewMP 0.99.4 - JPEG Export-Dialog - Compression - Invalid values may be entered
masterjp
Post by masterjp »
Thank you! :)
:arrow: Please fix the same problem in 'Save as' dialog. :!:
There is the same limit of values from 0-9 recommend.
This problem is supposed to be fixed in XnView MP 0.99.5. Please check and confirm the bug fix here.
masterjp
Post by masterjp »
Thank you very much for the fast und good bug fix of the XnViewMP 0.99.5 release!
