0.99.6 MacOS: EXIF field not showing on (HEIC) image thumbnail
Miura
Post by Miura »
XnView MP MacOSX
Version 0.99.6 64bits (Dec 10 2021)
I believe the screenshot below explains quite a lot by itself:
Actual behaviour (bug):
Althought I do see several 'types of dates' in the ExifTool, I can't get any of the field to show up in the thumbnail. Neither with a premade label nor with a custom label.
Expected behaviour:
From what I can find on these forums Exif and HEIC (and the combination of the two) are supported in my version. Therefor my expected behaviour is:
The same dates should be displayed in the thumbnail as are visable in the ExifTool
Re: 0.99.6 MacOS: EXIF field not showing on (HEIC) image thumbnail
This problem is supposed to be fixed in XnView MP 0.99.7. Please check and confirm the bug fix here.
Miura
Post by Miura »
It indeed seems so, thanks!
