Preview thumbnails are not rotated
FKCapitalism
Post by FKCapitalism »
xnview wrote: Mon Feb 21, 2022 7:15 am
FKCapitalism wrote: Fri Feb 18, 2022 5:37 pm Update, somehow it does manage to save orientation for some files, its unknown to me how.
All there ARW files are new from today.
Could you send me a ARW file?
Strange enough as i open folder with this three images today it shows proper rotation for all three images and all other images also that were broken few days ago. I will study further how to reproduce this bug.
P.S. This bug (images thumbnail on folder view are always rotated for horizontal images) still persists, and i was not able to fix it by any means. Can you reproduce it?
FKCapitalism
Re: Preview thumbnails are not rotated
I was able to identify what makes rotation broken in my case and how to reproduce it.
1. Either copy ARW file to new folder or delete Thumb.db & XnView.db inside C:\Users\<username>\AppData\Roaming\XnViewMP
2. In xnview.ini change startInFull=2 to startInFull=0 (I don't know what option inside tools > Settings this line corresponds to).
3. Now open ARW file by double clicking and see previews generated perfectly fine.
4. Close XnView and double click ARW and see thumbnail rotation is broken.
5. You can go View > Rebuild thumbnails and it fixes problem temporary until your restart XnView and thumbnail rotation is broken again.
Files https://www.upload.ee/files/13908928/Ne ... r.zip.html
Not the same problem, i can reproduce with RAW
FKCapitalism
xnview wrote: Tue Feb 22, 2022 12:45 pm Not the same problem, i can reproduce with RAW
How about this bug when thumbnails show sideways for folder preview only, i think its separate issue because when i click view > rebuild thumbnails rotation does not change even temporary.
FKCapitalism
xnview wrote: Mon Mar 28, 2022 10:18 am This problem is supposed to be fixed in XnView MP 1.00 beta. Please check and confirm the bug fix here.
This bug is fixed and working fine, thanks.
P.S. Please also look at this bug its similar, yet not related.
