Slideshow background color not working
somedude
Post by somedude »
Hi, I'm using XnView MP version 1.0 64-bit on a Mac M1.
If I go into a folder and select all the pictures then click the slideshow button in the toolbar a window pops up with the slideshow options.
Next, If I go to the "settings" tab and click the swatch beside "background color" a color picker window shows up.
If change the color (e.g. choose RGB Sliders, then move the sliders the swatch in that window changes to grey (like I want it to).
But when I click "okay" the window closes.
If I click the slideshow button in the toolbar again the background color remains black (unchanged).
Note, I can successfully change the background color in the lower "show information" section.
Not sure if this is a bug or if I'm doing something wrong.
Re: Slideshow background color not working
This problem is supposed to be fixed in XnView MP 1.01. Please check and confirm the bug fix here.
somedude
Post by somedude »
It doesn't look like the Mac installer is up yet. I will wait until it has been released and then try it out. Thanks for the update info!
the mac version is here
somedude
Post by somedude »
Ah! I missed it somehow. I will try it later tonight. Thanks.
somedude
Post by somedude »
It works properly in the new version! Thanks :)
Would you happen to have any insight on this other post I made? viewtopic.php?p=179078#p179078
