Suggested Category Set always empty
bwmarrin
Post by bwmarrin »
I'm using XnView to cull/tag images and I love it :) I'm using version 1.0.
On the Category Sets tab the Suggested section is always empty. It sounds like a cool feature that I assume would work similar to the same feature in Lightroom that I've used in the past.
Is there a setting or something I need to do so that the Suggested set gets populated with items?
Re: Suggested Category Set always empty
do you have 'Settings>Metadata>Automatically apply ....'? It seems that 'suggested' has a bug with this setting
bwmarrin
Post by bwmarrin »
xnview wrote: Thu Aug 11, 2022 12:41 pm do you have 'Settings>Metadata>Automatically apply ....'? It seems that 'suggested' has a bug with this setting
Yes, I have "Automatically apply parent category" selected. It's super handy having that since it reduces the number of categories I have to add to everything :)
This problem is supposed to be fixed in XnView MP 1.02. Please check and confirm the bug fix here.
Gwenael Q.
Post by Gwenael Q. »
"Suggested" category set not empty albeit "Automatically apply parent category" option selected. Thanks for fixing !
Tested with XnviewMP 1.3.
