Capture window's minimum width is too wide 1907px
Anibina
Post by Anibina »
System
XnView MP Windows, Version 1.02 64bits (Aug 24 2022)
Description
The Tools > Capture... window, has a minimum width that is too wide, 1907px.
There's a lot of empty space in the middle of the window.
And the Capture window can only be dragged wider, taller, or shorter (as long as all controls are visible),
But the Capture window can't be dragged narrower than 1907 pixels.
When the XnView MP window is on a 1920x1080 display, when opening: Tools > Capture...
Then the Capture window almost fills the width of the display.
When the XnView MP window is on a 1280x1024 display, when opening: Tools > Capture...
Then the right side of the Capture window extends outside the display's right side.
Expected
The Capture window shouldn't fill the width the display (maybe it's based on the width of the primary display).
And it should be possible to resize the Capture window so that there is less empty space in the middle.
Re: Capture window's minimum width is too wide 1907px
This problem is supposed to be fixed in XnView MP 1.3.0. Please check and confirm the bug fix here.
Anibina
Post by Anibina »
Fix confirmed, the Capture window opens with a minimum size now, and it's resizable in all directions. Thanks
