XnView: MP 1.3.0 64bits (Sep 6 2022)
OS: Windows 64bit (21H1), display resolution 3840x2160, win scaling 150%
Curves dialog.
Few issues with mouse hover over curve area.
2. open curves dialog: Image menu -> Adjast -> Curves...
<Default> preset is selected by default
Issue A
3. hover mouse cursor over chart area
Preset name turns blank
Issue B
3. tick "Apply to image" checkbox
4. modify curve and save as Custom preset
5. select <Default> preset
6. select Custom preset
Custom preset is selected, but its settings have not applied neither to chart area, nor to image
7. hover mouse cursor over chart area
only now its settings applied
Actual behaviour:
check video
Expected behaviour:
a) Preset name shall not disappear when cursor hovers over chart area.
b) Custom preset shall to apply its settings to chart area and image (if checkbox selected) immediately on selection.
1.3 - BUG - curves dialog - preset blank / chart area onhover
Re: 1.3 - BUG - curves dialog - preset blank / chart area onhover
if you change the curve, preset name is cleared
Agree, but my issues are slightly different.
I have updated/rephrased initial post and split video file.
v 1.4.0b1:
issue A - still remain
issue B - fixed
issue B - fixed
right will be fixed in beta 2
fixed in 1.4.0b2
