Can't convert file with Japanese filename to JPEG XL
andibad
Post by andibad »
Hello, i have problem convert image to jpeg xl when the filename is containing japanese character. Is seems the problem only for jpeg xl, other format is seems working fine.
XnView: MP 1.3.1 - 64 bit and older
Windows 10 and Windows 11 64bit
Intel gen 12 H series
Re: Can't convert file with Japanese filename to JPEG XL
This problem is supposed to be fixed in XnView MP 1.4.0. Please check and confirm the bug fix here.
andibad
Post by andibad »
I already testing it, and is working now.
thank you for fixing it dev :)
