Error when browsing specific folder
cristobal
Post by cristobal »
I have been using xnview (minimal edition, or whatever it's called) for more than a year, and I was about to declare it my all-time favourite, when...
_________________________
AppName: xnview.exe AppVer: 1.80.0.0 ModName: xnview.exe
ModVer: 1.80.0.0 Offset: 001621a4
... this is the error report I keep getting whenever I try to open a - specific - new folder, with some 100 or so pics. I downloaded & installed all the plugins available, but no success.
OS: w-xp sp2, with all the latest updates installed 8)
reminder for smokers:
it's not the cough that carries you off
it's the coffin they carry you off in
Xyzzy
Post by Xyzzy »
Download latest beta version (RC1) from New/Open forum (first topic) and check again.
If you don't feel like running beta software, download latest official version, ie. 1.80.3 and try it.
X.
cristobal
Post by cristobal »
Xyzzy wrote:Download latest beta version (RC1) from New/Open forum (first topic) and check again.
X.
thanks, but I already HAVE that version (1.80.3) installed :(
Xyzzy
Post by Xyzzy »
So please try with RC1 or wait till 1.82 release. Maybe your problem has already been solved there.
X.
cristobal
Post by cristobal »
Xyzzy wrote:So please try with RC1 or wait till 1.82 release. Maybe your problem has already been solved there.
X.
I did as you suggested, & installed the RC1, but the problem remains: as soon as I open the folder in question in thumbnails, the same report appears after showing some 3 or 4 thumbnails... :(
let's wait for the official release... thnx again :!:
Xyzzy
Post by Xyzzy »
Probably a broken file makes XnView crash. Could you determine the file crashing XnView and send it to Pierre (author)? If the file is too big for e-mail, you can use file-hosting service, like rapidshare.de
Please verify also if file opens OK in another software.
X
Xyzzy
Post by Xyzzy »
I got the file, thank you cristobal.
I created bug report here:
http://newsgroup.xnview.com/viewtopic.php?t=4857
X.
