"filter by image" and [..] bug 1.82
goldenfingaz
Post by goldenfingaz »
<Moderator's note: This post (subject) has been edited>
found a bug, i have activated the "filter by image" option and i dont see the "..." when i activate "filter by all" i see the "..."
ckit
Post by ckit »
I think this is "by design" although the normal folders shouldn't shown as well.
goldenfingaz
i hope not, that sucks hard :x
Re: ... bug 1.82
goldenfingaz wrote:found a bug, i have activated the "filter by image" option and i dont see the "..." when i activate "filter by all" i see the "..."
In 1.80, you have not this problem?
goldenfingaz
yep on xnview 1.80.3 is all fine :)
Dreamer
Re: ... bug 1.82
Post by Dreamer »
But there is no such option ([..]), so it's normal.
Folders and [..] item could be always enabled/disabled (by options 'items displayed'), also if 'filter' is used maybe.
goldenfingaz
i have already activated the [..] option in "items displayed" it doesnt work when i use the "filter by image" or video or sounds or archiv.
Xyzzy
Post by Xyzzy »
'Items displayed' is used only for 'Custom" filter and has nothing to do with the others.
X.
goldenfingaz
lol im fool. thats the custom filter ? :?
ok i use now the custom filter works perfect :)
thanks for help
Dreamer
Re: ... bug 1.82
Post by Dreamer »
But if you need [..] item, you can't use filter, so what about this?
Dreamer wrote:Folders and [..] item could be always enabled/disabled (by options 'items displayed'), also if 'filter' is used maybe.
goldenfingaz
yes, cant use filter or i must use the custom filter like now.
not good i think :(
goldenfingaz
problem fixed in 1.82.1
goldenfingaz wrote:problem fixed in 1.82.1
Good to read. :-)
We should investigate this a bit further (but not in this topic). I really think that the "Custom filter" settings and the other filters are a bit confusing. See also my post in topic Filter vs. Items displayed.
goldenfingaz
lol not really fixed, i only see the [..] when a activate [..] in "items displayd" but now it works with the filter im confused :|
Dreamer
Post by Dreamer »
goldenfingaz wrote:lol not really fixed, i only see the [..] when a activate [..] in "items displayd" but now it works with the filter im confused :|
[..] and folders are always visible if they are enabled in options - items displayed. I think it's good.
But folders are always visible, even if they are disabled in options - items displayed - a bug - it should work the same as [..].
