SE: Options to xnview Options window
Dreamer
Post by Dreamer »
Since Shell extension is a part of xnview, Shell extension options could be in xnview Options window. There could be also an option to disable/enable Shell extension quickly.
ckit
Re: SE: Options to xnview Options window
Post by ckit »
Dreamer wrote:Since Shell extension is a part of xnview, Shell extension options could be in xnview Options window. There could be also an option to disable/enable Shell extension quickly.
That's not possible, because some of the time you have to "log off" Windows to get Windows to stop using the DLL. I admit this doesn't happen with every version of Windows but it does happen!
Dreamer
Post by Dreamer »
You mean just this is not possible, right?
What about just hide it / remove all items form context menu?
And - what about first part of my suggestion?
ckit
Post by ckit »
Dreamer wrote:You mean just this is not possible, right?
Yes, correct.
I'm not sure I see the point in hiding it / removing it from the context menu.
The first part is fine.
Dreamer
Post by Dreamer »
Yes, correct.
OK, never mind, I'll start another topic with another suggestion...
OK. I'll suggest more options, so it would be better (but not too much).
Dreamer
Post by Dreamer »
ckit wrote:
Dreamer wrote:There could be also an option to disable/enable Shell extension quickly.
It is possible with Win XP - more here (your hint ;) ).
ckit wrote:I'm not sure I see the point in hiding it / removing it from the context menu.
For example, in ZIP version, you can't install Shell Extension without that hint (above). Another reason, user cannot disable / uninstall it now (link).
And sometimes you need it and sometimes don't - e.g. in explorer / file manager with thumbnails view it's not needed, but in list / details view it is needed.
