Option to auto remove unused cache items after X days...
TsunamiZ
Post by TsunamiZ »
Please add an option to auto remove unused cache items after X number of days [similar to how web cache is handled by web browsers]. This will make cache maintenance a lot easier. Thanks.
Tommy
Post by Tommy »
and it will save a lot of drive space
I support
:) Hello !
I support this proposal!
- I guess it might be configurable at the days amount.
- To avoid Options pages as so full as eggs, it could be simply an INI entry, since we have not any need to change it very often, something like :
ClearChacheEach = Flag
where "Flag" is the period between the purges in days …
:mrgreen: Kind regards,
TsunamiZ
Re: I support
Post by TsunamiZ »
It's would be nice to have the numbers of days input field in the cache category. :wink:
Why not ?
:D Yes, this is quite conceivable too and should be handy, but needs to add some stuff (a few, most certainly) to the programme, and then into N… language-DLLs, causing an extra-job to Pierre who is already overworked…
:mrgreen: KR
Olivier_G
Post by Olivier_G »
You should be able to specify: Remove Cache unused after X days and Limit Cache to Y MB (based on last use and frequency...).
Those options should appear directly in the Options 'Cache' window.
Olivier
ckit
Post by ckit »
I support this request.
TsunamiZ
Post by TsunamiZ »
Olivier_G wrote:You should be able to specify: Remove Cache unused after X days and Limit Cache to Y MB (based on last use and frequency...).
Olivier
Yes, forgot to mention the cache size limit. But it should also allow unlimited cache size [when set to 0], so it won't interfere with amount of cached items in x days for some people.
Go to R… ?
—> Olivier_G
:) Hello !
<½Joke>This is part of GUI, so I agree if you go to help Pierre for the whole series of language-DLLs to update… Not too far for you, just 150 km :D </½joke>
:mrgreen: KR
Xyzzy
Post by Xyzzy »
And how should they cooperate? Most restrictive first? Least restrictive first? Selectable? One with set value supersedes the other set to 0?
X.
Danny
Post by Danny »
Olivier
I like the 'Limit Cache to y MB' idea. I do not like the threadstarter's idea. Why throw out thumbnails simply because they've been created a long time ago? Doesn't make sense to me.
Olivier_G
Post by Olivier_G »
Xyzzy wrote:And how should they cooperate? Most restrictive first? Least restrictive first? Selectable? One with set value supersedes the other set to 0?
I was thinking about the most restrictive one only (it should at least be the default behaviour, otherwise people may not understand why their last setting is not applied) and 0=unlimited being superseded by the other setting.
It could also be something like this, if you want more flexibility:
Remove from Cache: when unused after [X] days  - [ OR|v] - to limit Cache to [Y] MB
                                                 [AND| ]
                                             (dropdown list)
Olivier
PS1: I believe some people are more confortable with "I'm not going to check that often files older than 2 weeks, because it's the way I work..." rather than "367MB is my limit today"... ;-) -> therefore both settings seems useful.
PS2: Limiting Cache to [Y] MB may be tricky: which files to remove? Consider last access? How often? Filesize? Filetype?...
TsunamiZ
Post by TsunamiZ »
Olivier
And limiting to cache size can be a bad idea. Imagine some of your recent cache items being thrown out because you reached your cache size limit too soon.
TsunamiZ
Post by TsunamiZ »
Remove oldest cached items first. :wink:
A large cache can be a nuisance due to its size. And access to it might be even slower (not necessarily).
I like the idea of setting a cache limit and kicking out oldest entries from cache.
A limitation with date would be the deluxe version, but it will make things more complicated than actually needed. So I'd prefer the normal version (without maximum period for old entries).
