Zoom at poor quality when browser fullscreen...
TsunamiZ
Image zoom quality defaults to poor quality when fullscreen from browser [not viewer]. Images can't fit to screen with high quality resampling. Please fix this. Thanks.
Re: Zoom at poor quality when browser fullscreen...
You are in zoom more than 100%?TsunamiZ wrote:Image zoom quality defaults to poor quality when fullscreen from browser [not viewer]. Images can't fit to screen with high quality resampling. Please fix this. Thanks.
TsunamiZ
Yes, to fit smaller pictures to screen size.
Ok, currently high quality is made only for zoom lesser than 100%, but i'll add soon this featureTsunamiZ wrote:Yes, to fit smaller pictures to screen size.
TsunamiZ
Toe
On mine, in fullscreen view I normally only get high-quality resize when the image is being reduced, not enlarged. But if I first view the image in a window and then go to fullscreen (instead of going straight from browser -> fullscreen) then I can get high-quality zoom for all images. This isn't exactly an acceptable solution for me, though...
TsunamiZ
