Sony EXIF and Thumbnails Rotated
ckit
Post by ckit »
I was moving through Firefox's cache and noticed that some JPEG's with EXIF info the thumbnails for them were rotated 90 degrees when they shouldn't be.
The images in question are of a Adult nature so I can't send them to you, however I can dump the EXIF info here...
Image description                :
Camera Manufacturer              : SONY
Camera Model                     : CD MAVICA
Orientation                      : top-left (1)
X Resolution                     : 72
Y Resolution                     : 72
Resolution unit                  : Inch
Date modified                    : 2003:09:23 13:42:26
YCbCr Positioning                : co-sited (2)
Exposure time [s]                : 1/80
F-Number                         : 2.2
Exposure program                 : Normal (2)
ISO speed ratings                : 100
EXIF version                     : 02.20
Date taken                       : 2003:09:23 13:42:26
Date digitized                   : 2003:09:23 13:42:26
Components configuration         : YCbCr
Compressed bits per pixel        : 2
Exposure bias value              : 0/1
Max aperture                     : F2.0
Metering mode                    : Multi-segment (5)
Light source                     : Unknown (0)
Focal length [mm]                : 12.2
FlashPix Version                 : 01.00
Colour space                     : sRGB
EXIF image width                 : 1280
EXIF image length                : 960
Interoperability offset          : 646
File source                      : DSC
Scene type                       : A directly photographed image
Custom rendered                  : Normal process (0)
Exposure mode                    : Auto (0)
White balance                    : Auto (0)
Scene capture type               : Standard (0)
Compression                      : 6
X Resolution                     : 72
Y Resolution                     : 72
Thumbnail offset                 : 865
Thumbnail length                 : 2928
Please note, in XnView options - I have "Rotate images based on EXIF orientation" set to disabled!
Update:
I've cleaned out XnView's cache and still the problem remains.
Olivier_G
Post by Olivier_G »
Are you using Browser>Thumbnail>Use embedded thumbnail ?
(another program has maybe rotated that embedded thumbnail)
Olivier
ckit
Post by ckit »
Olivier_G wrote:Are you using Browser>Thumbnail>Use embedded thumbnail ?
Olivier
Yes, I was, after disabling it and deleting the cache again - it's fixed.
Thank you!
Closed.
