File already exists: skip all
marsh
Post by marsh »
A new button to 'skip all' files would make updating another directory faster when you don't actually want to examine each matching image.
Copying and pasting using <ctrl + c> and <ctrl +v> using Xnview is not good for updating directories. It automatically creates copy of each file without asking to skip any.
Dreamer
Re: File already exists: skip all
Post by Dreamer »
marsh wrote:A new button to 'skip all' files would make updating another directory faster when you don't actually want to examine each matching image.
I fully agree. But I think we need also Replace all and Rename all.
So I suggest this option:
[x] Apply to all files [Replace] [Rename] [Skip] [Cancel]
marsh wrote:Copying and pasting using <ctrl + c> and <ctrl +v> using Xnview is not good for updating directories. It automatically creates copy of each file without asking to skip any.
Yes, "thumbnail dialog" should be shown here too IMO.
"[x] Aplly to all files" would be a good and common solution. You have my support.
ckit
Post by ckit »
I support all of this :)
Dreamer
Post by Dreamer »
And what do you think, it should be always saved, or always disabled, or saved and then disabled at next xnview startup?
Not sure that 'Apply to all' is good, but have not the solution :-(
Dreamer
Post by Dreamer »
Why?
neutrino1
Post by neutrino1 »
I agree except I do not think that Cancel would need to apply to all because it would stop the copy operation.
