some pictures auto show left rotation!!
jiichen
Post by jiichen »
XnView 1.82.4 on Windows XP SP2
picture is can speak the bug!
Original Picture:
marsh
Post by marsh »
The image is rotated according to EXIF data when the following option is used:
Read>[x] 'Rotate Images based on EXIF orientation'
Is Xnview handling this option correctly? Pierre would know...
The EXIF information says:
Orientation                   : left-bottom (8)
Right, marsh, it's very likely that XnView rotates the images according to the EXIF information, which is wrong in jichen's case.
FAQ "How to rotate images automatically" describes the above problem and what you can done about it.
jiichen
Post by jiichen »
Oh! I see!
:shock:
This is my wrong! :|
And Thanks helmut & marsh very much. :wink:
jiichen wrote:Oh! I see!
This is my wrong!
No problem, you are welcome. :-)
