how to resize without resampling
Julien
Post by Julien »
hello,
I try to resize a photo that is too big, but I'd like to do it without quality loss, so is there a way to do it without resampling like in photoshop?
thanks
Julien
Re: how to resize without resampling
Julien wrote:hello,
But if you resize a photo, you have always a quality loss.
Drahken
Post by Drahken »
1) If you resize a pic without resampling, the pic will look much worse than if you do resample it. For the best results, I strongly suggest using either the lanczos or hanning resample filters.
2) If you really want to resize without resample, choose "nearest neighbor" in the resample dropdown. "Nearest neighbor means that no resample filter will be used.
Julien
Post by Julien »
ok thank you
