FreeCommander - Freeware
All non-XnView related: softwares, formats, imaging, photography...
Postby Dreamer » Sun Jun 15, 2008 7:35 pm
FreeCommander 2008.06 has been released!
Important changes in the version 2008.06
    New: Multi rename tool
    New: Built in FTP: activate FTP under Settings->Drives: Show FTP as drive
    New: Synchronize folders - exclude filter possible
    New: Synchronize folders - option for "ignore 1 hour time delay"
    New: Lock toolbars
    New action: Create new file
    New action and pushbutton in toolbar: New file
    New: Settings->Toolbar: Show menu as toolbar
    New: Settings->Toolbar: Drawing style
    New: Settings->Icons: Icons in main menu (Use small icons; Use the same size as in toolbar)
    New item in the popup menu for tabs: Lock - navigation to subfolders
    New: Settings->View: Width of Go Up strip
    New: Settings->View->Toolbars: Use big icons
    New: Settings->View->Splitter: Show "Swap panels" button; Width of splitter
    New: Settings->Quick search/filter: Deactivate filter for folder change
    New: Save scroll bar position for tabs
    Changed: F5/F6 shortcuts changed to copy/move with dialog
    Bug: High CPU Usage after taking Desktop Snapshots
    Bug: Password is shown, when user enter password for unRar files
    Bug: Favorite folders - multibyte characters do not work
    Bug fixed: Vista folder e:\windows\winsxs can not be open if "View folder size" option is active
    Other bugs fixed
The latest version is available on the FreeCommander download page.
Dreamer
Dreamer
Postby Dreamer » Tue Aug 05, 2008 10:01 pm
FreeCommander 2008.06a has been released.
New: FTP connection details option 'Show hidden files'
New: multi rename - pattern possible in 'replace with' field
New: multi rename - new column: Created
New: multi rename - Remove from the list
New: multi rename - Sort per drag&drop possible
New: display info about count of files to rename - in the status line of the multi rename dialog
New: add current folder to the list of favorite folders Ctrl+Shift+V
New: search window - new columns added: Created and Type
New: settings - customization of the function bar possible
New: folder compare extended - compare subfolders possible http://www.forum.freecommander.com/view ... =2839#2839
Changed: definition of custom columns
Changed: refresh for tree view improved
Bug fixed http://forum.freecommander.com/viewtopic.php?t=455
Bug fixed http://forum.freecommander.com/viewtopi ... =2439#2439
Bug fixed http://forum.freecommander.com/viewtopi ... =2398#2398
Bug fixed: function bar F5/F6 caption change to German if default for Settings->Confirmations changed http://www.forum.freecommander.com/viewtopic.php?t=926
Bug fixed: drag&drop - access violation at address 005cd80f in module freecomander.exe read of address 00000024
Bug fixed: the FTP option 'Show file attributes as a number' won't be saved
Bug fixed: auto-completion is not active http://www.forum.freecommander.com/viewtopic.php?t=954
Bug fixed: ftp file delete dialog is in German http://www.forum.freecommander.com/viewtopic.php?t=958
Bug fixed: graphical bug http://www.forum.freecommander.com/viewtopic.php?t=941
Bug fixed: zip file does not open if passed as a program parameter
Bug fixed: Ctrl+F1 opens help window http://www.forum.freecommander.com/viewtopic.php?t=964
Bug fixed: properties, using Alt+Tab, or right click context menu, doesn't work (Vista) http://www.forum.freecommander.com/view ... =2514#2514
Bug fixed: Enter key doesn't work in archive file (rar, cab)
Bug fixed: capitalization and use of small letters is not distinguished on FTP site http://www.forum.freecommander.com/view ... hlight=ftp
Bug fixed: upload to FTP server fails if the server does not support SIZE command.
Bug fixed: multi rename - some case options don't work properly http://www.forum.freecommander.com/view ... =2634#2634
Bug fixed: md5-creation not possible for filename with '..' http://www.forum.freecommander.com/view ... =2699#2699
Bug fixed: http://forum.freecommander.com/viewtopi ... 06a3b00fd6
Bug fixed: sort on date in search window is wrong for some timestamp formats http://www.forum.freecommander.com/viewtopic.php?t=953
Bug fixed: add FTP connection does not work with Enter http://www.forum.freecommander.com/viewtopic.php?t=1048
Dreamer
Dreamer
Postby Dreamer » Mon Sep 01, 2008 10:59 pm
FreeCommander 2008.06b has been released!
Important changes in the version 2008.06b
Bug fixed: Interface bug http://www.forum.freecommander.com/viewtopic.php?t=1117
Bug fixed: Descending sort on type and extension do not work
Bug fixed: Multi rename - DEL key always removes current line in the file list
Bug fixed: Changes in "Define favorite tools window" caused no refresh on toolbar http://www.forum.freecommander.com/viewtopic.php?t=1127
Bug fixed: Ftp option "Right as number" is saved only with the option "List files in Log (slower)"
Bug fixed: Define favorite tools issue http://www.forum.freecommander.com/viewtopic.php?t=1099
Bug fixed: It is not possible to use "=" character in quick search
Bug fixed: Sometimes file names are truncated
Bug fixed: Difficult selection with enabled Folder Size in NC-mode http://www.forum.freecommander.com/viewtopic.php?t=1181
Bug fixed: Wrong file order when using drag&drop to other program in NC-mode http://www.forum.freecommander.com/viewtopic.php?t=1180
Bug fixed: AV bug in multi rename dialog
Bug/New: FTP upload not possible for some servers; try to define the line "Command4FileExists=SIZE" in the server section of freecommander.ftp
New: File->Attributes/Timestamp... the checkboxes for attributes now have 3 states: checked, unchecked and not changed
New: Quick search - press the same key repeatedly for skipping to the next item (like Explorer)
New: Custom columns option "Autosize for 'Name' column"
Dreamer
Dreamer
Postby Dreamer » Fri Sep 19, 2008 11:58 pm
FreeCommander 2008.06c has been released!
Important changes in the version 2008.06c
Bug fixed: On some PCs the using of copy (Ctrl+C) and paste (Ctrl+V) functions is not possible due to a crash of FreeCommander.
Dreamer
Dreamer
Postby Dreamer » Sat Feb 21, 2009 9:22 pm
FreeCommander 2009.02 has been released!
Important changes in the version 2009.02
    New: Possibility to define several favorite toolbars.
    New: Flat view for files Ctrl+B
    New: Flat view for folders Ctrl+Shift+B
    New: Settings->Color/Font: Backgroundcolor for flat view
    New: Settings->Custom columns: Default profile for flat view
    New: Support side mouse buttons for back and forward navigation
    New: Multi rename - some new exif and mp3 properties added
    New: Automatically expand the tree view on tab change
    New: Action defined: Collapse selected node in the tree view
    Changed: Only one quick filter button
    Several bugs fixed
Dreamer
Dreamer
Re: FreeCommander - Freeware
Postby Dreamer » Sun Nov 15, 2009 11:53 pm
FreeCommander 2009.02a has been released!
Important changes in the version 2009.02a
Dreamer
Dreamer
Re:
Postby rebel » Mon Nov 09, 2015 2:26 pm
ikutluay wrote:It is good prpgram but it is not a good solution for me. Far is better. but i like console file managers..
I was just going to list FAR also, used it for years, much more efficient and more control than anything I've used so far...
http://www.farmanager.com/Far Manager 8)
"When the law is not applied equally to all people in a society what you are left with is suppression."
~elaine ossipov 2012
rebel
Previous
Return to Miscellaneous
Who is online
Users browsing this forum: No registered users and 0 guests
