Zoom lock on/off by default option
Moorg
Right now, zoom lock is OFF by default (when entering the application). In order to turn it on, the user must click the item in the context menu or use the shortcut.
I think having it ON by default would be more useful, and would really like an option in the Viewer settings that sets the initial value of the Zoom Lock. This would also not bother those who are happy with zoom lock being off by default.
Yes, support !
• Right, I miss such an option many times, hence I support this proposal !
Re: Zoom lock on/off by default option
Im' not sure that ON by default is good, but perhaps saving this setting???Moorg wrote:Right now, zoom lock is OFF by default (when entering the application). In order to turn it on, the user must click the item in the context menu or use the shortcut.
Ah, I much prefer it to be off by default! Perhaps an option to set initial behaviour?
Olivier_G
I like this idea of remembering previous "Zoom lock" setting... without having to add an option for it (+Default OFF on a fresh install).xnview wrote:Im' not sure that ON by default is good, but perhaps saving this setting???
Olivier
Moorg
Olivier_G
Olivier_G
Not the ratio
• In ß-1, the state of the command is saved through the sessions, but not the current zoom ratio when closing XnView (after the Loock Zoom has been set “ON”)… ???
Dreamer
herr_k.
robijn
veggen
+1 for this. And this should work in both full screen modes. It's waaaay to confusing having two different full screen modes, they really should behave identically.Olivier_G wrote:I like this idea of remembering previous "Zoom lock" setting... without having to add an option for it (+Default OFF on a fresh install).xnview wrote:Im' not sure that ON by default is good, but perhaps saving this setting???
jcarerra
Posting to an old thread, but it is the exact topic I am wanting to comment on...
Yes PLEASE, fix xnview to retain the set zoom and/or fit to settings across close/opens.
Every picture I open, I have to zoom in. Arghhhh. This seems so obvious that it should be retained.
Begging. Please. If you don't think that is good as a default for everybody, make it an option we can set. I'd like to be able to set "Fit to width" or a zoom percent.
