gerald1 wrote:This programme is so good and so fast I wonder if I have simply missed finding the two things I wish for.
However until I have these two features I cannot throw away ACDSee.
Thank you for the accolade.
gerald1 wrote:1. I cannot copy/move by drag-and-drop from the file panel to the folders in the tree. Yes, there is a right-click system but this is tedious if you want to copy/move to several different folders, and it has an very annoying habit of jumping to the first file when you move a file, instead of simply jumping to the next file.
Moving and copying
files is possible by just dragging the files to a folder in the folder tree (For copying press Ctrl key while dragging & dropping). But moving/copying
folders does not work, neither via drag&drop nor via 'Copy to, Move to' dialog, which is a real shortcoming.
gerald1 wrote:2. the batch renaming system does not have a find-and-replace feature.
Not quite sure what you mean, could you describe in more detail?
Currently, batch rename can be applied on the files selected, only.
I've tried to work around this limitation by:
1.) Performing a search and view the results of the search.
2.) Select the search results and apply a rename on the files in the search result.
--> Result is 'Error renaming file'
Cheers,
Helmut
