embedded thumbnails of CR2 RAW files not rotated in browser
imforumman
Post by imforumman »
Hi Pierre,
I'm not sure, there are so many threads about thumbnails... I'm not sure if this has been reported:
The embedded thumbnails of my CR2 files are not rotated in the browser according to the exif value (the preview is rotated correctly).
Thanks!
Re: thumbnails of CR2 RAW files not rotated via exif in brow
imforumman wrote:Hi Pierre,
The thumbnails of my CR2 files are not rotated in the browser according to the exif value (the preview is rotated correctly).
Thanks!
Do you have enabled option/Read/Rotate EXIF?
imforumman
xnview wrote: Do you have enabled option/Read/Rotate EXIF?
Of course, all other thumbnails are rotated according to their exif values, only the thumbnail which is integrated in the raw/cr2 file ins not rotated accordingly.
imforumman
confirmed
I just confirmed this by taking a picture in RAW+JPG mode and viewing the directory they were placed in:
the cr2 file:
- displays the integrated thumbnail (NOT rotated)
- the EXIF icon
- the thumbnail icon
the jpg file:
- displays the integrated tumbnail correctly rotated
- the EXIF icon
- the rotated icon
If you want, I can send you the files and a screenshot via mail. Note: the exif-data displayed in the properties of the cr2 file do NOT include the orientation field, so it may be that the dcraw lib you are using (or similar) is not extracting the complete exif data and thus xnview can't know about having to rotate it. (Other programs are able to extract the orientation information, so it is also contained in the cr2 file)
(This is the last stable version, not 1.9alpha, I have not tested that one, but unless large parts have been rewritten I'm thinking there is going to be no difference)
Re: confirmed
imforumman wrote:I just confirmed this by taking a picture in RAW+JPG mode and viewing the directory they were placed in:
the cr2 file:
- the EXIF icon
the jpg file:
- the EXIF icon
- the rotated icon
Yes please send me the files...
imforumman
Re: confirmed
xnview wrote: Yes please send me the files...
It's huge, but it's on its way...
imforumman
Re: confirmed
The SMTP Server program
orange.fr platform: said: 552 5.2.2 Over quota (in reply
    to RCPT TO command)
oops. I'll try later again.
Re: confirmed
    to RCPT TO command)
No please at xnview.com
imforumman
no, i used the wanadoo.fr
did you get the files i sent using sendthisfile.com?
Olivier_G
Post by Olivier_G »
Olivier
imforumman
Olivier_G wrote:Please, see how to contact the Author.
So, what is this now? Search the forum before contacting the author? Using the email address in the users profile seems like a realistic thing to do. Ohterwise, this needs be changed.
Pierre: did you get the files I sent via sendthisfile.com to your wanadoo.fr address?
Olivier_G
Post by Olivier_G »
imforumman wrote:So, what is this now? Search the forum before contacting the author? Using the email address in the users profile seems like a realistic thing to do.
Except that you used what is indicated near 'MSN Messenger' and lots of people keep an email for Messenger without using it for Mail (be it for spam or whatever reason).
I was trying to help, but obviously you don't need any, right?
This being said, Pierre: maybe you could remove the MSN Messenger address from your profile and add directly the XnView address in your Avatar to avoid that kind of situation... :?:
Olivier
imforumman
Olivier_G wrote:Except that you used what is indicated near 'MSN Messenger' and lots of people keep an email for Messenger without using it for Mail (be it for spam or whatever reason).
Yeah, you're so right: I saw an email address, selected it, ctrl-c, ctrl-v and all thought all was good. I should have looked. I should know better. And, yes, I shouldn't have gotten on your case for helping. It just seemed like another one of those moderator "search the forum before you post" comments, even though it wasn't. I'm sorry.
That being said, I do hate it when people have email address they don't check (anymore). I have my email software check six imap accounts and at least 10 others are redirected to one of them. If I don't want to use an email address, I delete it, giving anybody an error who sends mail to that address an error. And for spam: an adaptive spam filter catches 98.5% of the spam i recieve and ive gotten two false positives in 3 years.
evogel99
Post by evogel99 »
I can confirm that CR2 files are not rotated even if EXIF is enabled in READ options.
evogel99 wrote:I can confirm that CR2 files are not rotated even if EXIF is enabled in READ options.
Please, send me too a sample...
