Improve colours by file type…
—> Pierre
:) Good morning,
• The original thread is THERE, and unanswered since 2005, June 6th. :|
- I guess it's worth a glance… Please, could you consider an improvement of that locked feature ?
- All TC-users know that I mean ;) TIA !
:mrgreen: KR
XnView 1.90 <x>
Re: Improve colours by file type…
Clo wrote:—> Pierre
:) Good morning,
In TC, you can change default colour for extension??
ouistiti
Post by ouistiti »
:arrow: XnView
No problem with TC... :D
Friendly
Paul
1,77245385090552...
For ages !
—> Pierre
:) Good afternoon,
• Ho yes ! And that exists for years !
- Like Paul shows above, any colour can be assigned to any file-type at will !
- You can even assign the same colour to two extensions (or more) when needed, i.e. HTM and HTML, TIF and TIFF…
• Just to illustrate the issue in XnView, I think you saw in the original thread that the hard-coded colours are not easy to distinguish, especially with a light-grey background like here on the board.
- Below, that one can get with other BGs :
———— ImageImageImage
• In TC, that function uses the Search features, and XnView has this, has it not ? This is saved in the main INI file as :
[Colors]
ColorFilter1=*.exe
ColorFilter1Color=16711680
ColorFilter2=>files without extensions
ColorFilter2Color=$006FD4
ColorFilter3=*.txt
ColorFilter3Color=4210816
- Please, notice that the inverted hexa colour-code is supported in TC, this is too a missing feature in XnView.
- It's much easier to change colours in this way by hand than to get a headache using the "complements" thingy … ;)
- Files without extension needs an extra section, but I guess this is not really useful for XnView…
• Hoping this could help you to improve the programme,
:mrgreen: KR
Olivier_G
Post by Olivier_G »
I believe this is implemented in Beta 5: in the INI file [Browser] here is what I have:
ColorFilter1=jpeg, 237 237 202
ColorFilter10=psd, 255 255 227
ColorFilter11=pcd, 235 215 235
ColorFilter12=psp, 237 208 163
ColorFilter13=pict, 202 202 255
Claude, can we close this topic?
Olivier
The opposite!
—> Olivier_G
:) Hello !
• No yet, please, because :
1. Pierre has implemented exactly the opposite of that I quoted as a template (the Total Commander system).
- So, he has kept only different backgrounds colours, while that I said in the TC INI are colours for the text !
- This can be seen on the “Paul-Ouistiti”'s capture too…
2. Supposing that we could live with this (adjustable backgrounds, much less easy to spot, since we can't use too dark ones with a single black font colour…), it's buggy.
- I tested a red background for *.png, and I have it too for an *.icl file ! :shock:
- Moreover, this ICL contains indeed icons only, like it should !
3. I can't get an answer from Pierre about the support of the inverted hexa code - I even requested it again recently elsewhere, nope - that is related to the next point.
4. Personally, that doesn't bore me a lot to change these colours by hand in the INI. Indeed, we will document that in our Manual, since it has a special chapter for this.
- So, whether this feature might stay such as for a certain period, the “Aunty Agatha”s will not use it, I guess…
- Unfortunately, they are the kind of users who needs that the most (old eyes…)
- To have it as complete, we might get a GUI Option, there is a huge free room remaining on the File List Options page…
We could simply choose the colours from the current palette, since now the custom colours are saved !
5. May we add types by hand in the INI ? Important question !
• Don't you think that this might be discussed a bit more ? ;)
:mrgreen: KR
Re: The opposite!
Clo wrote:—> Olivier_G
:) Hello !
- This can be saw on the “Paul-Ouistiti”'s capture too…
Houps, ok. ColorFilter is for text color, not background...
I add BColorFilter for back color
ouistiti
Post by ouistiti »
:arrow: Pierre
:D
Please, don't forget that we need a configurable single background colour for the lists.
So, the users who prefer dark BG and light colours and those prefering the opposite will be happy !
TIA
Paul
1,77245385090552...
Dreamer
Post by Dreamer »
ouistiti wrote:Please, don't forget that we need a configurable single background colour for the lists.
TIA
Paul
Oh yes, there is an option for thumbnails view background, but no option for other views and folder tree.
Is it possible to make a default background color option? There are so many small options and such a basic option is missing.
Dreamer
Everybody happy !
—> Dreamer
:) Hello !
• To illustrate the new function as quite accomplished, I spent some hours to draw GUI options,
like I wished to get above (for later, certainly) :
——— Image
• The user can choose to use the colours or not…
• In both cases, s¦he can choose general background and font colours… ;)
• There is indeed a default set of colours in the INI - like currently for the BGs - having a limited amount of file-types.
- So, one can add a new type to the default-set, and also remove one from it.
• It could be possible to load custom sets of predefined colours-filters from extra INI files, let's say like <Colour_filter_1.INI>,
for advanced users able to write such files (not very complicated, though).
• Separately, it could be possible to choose a font-face, font weight, font-size from the small bottom-right section.
- It might be applied in all cases, colours or not.
- This should be useful for those having a lot of files with hyper-long names¦comments, so a narrow¦smaller font helps!
• Indeed, the layout is far to be perfect, I draw all by hand… It's only to show the necessary items, from my point of view…
:mrgreen: KR
ckit
Post by ckit »
Nice and even interesting but postponed for 1.91 or 2.0.
Let's pray
—> ckit
:) Hello Chris !
• Who knows ? Image
• Waiting for this, anyway there are missing items to use the feature, even changing the values by hand in the INI…
- In example : The grid lines colour…
:mrgreen: KR
ouistiti
Post by ouistiti »
Waiting for this,...
It's not urgent, but useful to be rapid ! :wink:
Paul
1,77245385090552...
Dreamer
Post by Dreamer »
Perhaps just the single option for background/text color for file list / folder tree could be added in 1.90, it's really a basic option and looks simple, Pierre?
Small sub-suggestion, for format background colors default font color should be used always.
For other Clo's suggestions it's too late IMO.
Dreamer
TIA
Paul
I use standard background color for list view
