[Fixed] [REQ:] Show embedded thum. acc. their EXIF orientat
Moderators: XnTriq, xnview
Locked
Lesmo16
Post by Lesmo16 »
Using the embedded thumbnails is a very fine feature and should drastically decrease loading time! :D
But please, it should be possible to show these embedded thumbnails according to their EXIF orientation flag.
I think that is a very important feature, and would highly improve xnView.
BTW: The normal thumbnails (not embedded) may correctly orientated too. :wink:
Everyone who believes in telekinesis, raise my hand!
Re: [REQ:] Show embedded thumbnails acc. their EXIF orientat
Lesmo16 wrote:... But please, it should be possible to show these embedded thumbnails according to their EXIF orientation flag.
In the options dialog, category "Read", there's the option "Rotate images based on EXIF rotation". This works very well for JPG images, not sure whether it also works for the the embedded JPG thumbnails.
Lesmo16
Post by Lesmo16 »
Helmut wrote:In the options dialog, category "Read", there's the option "Rotate images based on EXIF rotation". This works very well for JPG images, not sure whether it also works for the the embedded JPG thumbnails.
Yes, that's right for the preview image.
But it doesn't work neither for embedded nor for normal thumbnails. :(
Have you try this out in 1.80? In 1.80, not only the preview and view is rotated automatically, but also the thumbnails. For automatically rotated images a special symbol appears next to the thumbnail so that the user knows.
Lesmo16
Post by Lesmo16 »
Helmut, thanks for your information! :)
In this thread we're talking about nothing other. :wink:
Yes, you're right of course! :? Got some modified JPEGs ...
It works really fine! :D
Lesmo16 wrote:...It works really fine! :D
Good to hear. :-)
Does it work for both normal and embedded thumbnails or for normal thumbnails, only?
Lesmo16
Post by Lesmo16 »
Helmut wrote:Does it work for both normal and embedded thumbnails or for normal thumbnails, only?
Works for both - Pierre has done a great job! :D
Dreamer
Post by Dreamer »
So there is no problem?
Can I move this topic to "Solved Bugs..." forum?
Lesmo16
Post by Lesmo16 »
Rotate embedded thumbnails according to their EXIF orientation flag
- SOLVED
Drastically decrease thumbnail loading time with embedded thumbnails
- SOLVED
Dreamer
Post by Dreamer »
Lesmo16 wrote:Rotate embedded thumbnails according to their EXIF orientation flag
- SOLVED
- SOLVED
OK, moved
Locked
