Blocky presentation in 1.5.1?
Re: Blocky presentation in 1.5.1?
Klaus1189 wrote: Fri Aug 11, 2023 4:10 pm I retested 1.5.3, same issue
I can't reproduce. I've tried 'Bicubic' for Zoom out...
Could you post screenshots with different zoom settings
Klaus1189
Post by Klaus1189 »
Sorry for late reply. I made a video. Even on a phone the "blockyness" is visible.
https://drive.google.com/file/d/1ULlnEr ... sp=sharing
Look at the orange text.
I doesn't matter which zoom steps. Every zoom step is affected.
I use always latest Nvidia driver for RTX40 card. I use Windows 10 Pro 22H2 latest updates as of today. Nothing changed. Always can replicate the issue.
Bilinear is fine but all other are affected.
This issue is introduced in 1.5.0
Last working is 1.4.5
My current workaround is to use Bilinear.
Reset settings did nothing.
i send you a PM
Klaus1189
Post by Klaus1189 »
OK?
This problem is supposed to be fixed in XnView MP 1.5.4. Please check and confirm the bug fix here.
Klaus1189
Post by Klaus1189 »
Issue is fixed. Thank you very much.
What is "best" scaler of the available ones?
