Show colour info not saved…
Olivier_G
Post by Olivier_G »
No, I would prefer:
helmut wrote:[View]
QuitColorInfoMode <value>
0: Quit mode when closing image
1: Quit mode when exiting XnView
2: Never quit mode automatically
(which is really different from the implemented behaviour in Beta 2)
It could also be described as:
0: ON for current window only
1: ON for current session only
2: Always ON
Olivier
GeorgD
Post by GeorgD »
xnview wrote:Why?? I think that it's clear...
In view mode, i edit the pic. Hence, ColorInfo could be understood as the palete color info, and if not kept, everything will be grayscale when going to next image. Other interpretations are possible as well. IMHO the name shall be as closely related to the tool name in the menu as possible. Moreover, "Normal" is not telling anything excelpt it's the default behaviour (but how does it behave?), see post of Olivier_G.
Manual is explicit
:) Hi !
• I said I added a comment in the Manual :
Changed since 1.90 ß2. The display of Colour Information and coordinates as a pop-up info-text is no longer saved by default,
neither for the next¦previous image, nor for the whole session with the 1.90 version.
To get the mode you prefer, use that entry with the appropriate flag.
• Same in the French version, and I guess it's largely clear and sufficient. No need to split hairs… :P
:mrgreen: KR
Olivier_G wrote:No, I would prefer:
helmut wrote:[View]
2: Always ON
Really i don't understand, for me it's the same thing.
xnview wrote:So, if I understand correctly:
- 0 = ON for current image only
- 1 = ON for current window only
- 2 = Always ON
This is not 100% correct. This setting is about switching colour info mode OFF, not on. Using the word ON leads into the wrong direction.
O.k., some more explanation why I want to have changed wordings. (Olivier has explained most of it, already).
Currently we have:
ColorInfo in [View]
0: Normal
1: Keep only with prev/next file
2: Keep always
The setting is about the duration / keeping / quitting of the ColorInfoMode. This is why the naming of the setting shouldn't be just ColorInfoMode. (Or the naming of settings will become inconsistent as soon as you add another setting for the colour info mode since you will have to be more verbose, then).
As Olivier has pointed out, "Normal" means nothing to users because they do not know what is normal.
This is why I have suggested a different name for the setting and different comments for the values. All the rest is the same.
helmut wrote:O.k., some more explanation why I want to have changed wordings. (Olivier has explained most of it, already).
Currently we have:
ColorInfo in [View]
0: Normal
2: Keep always
Ok, if you want only to change the label in Whatsnew of this option :-)
xnview wrote:Ok, if you want only to change the label in Whatsnew of this option :-)
Label in Whatsnew and name of setting: "QuitColorInfoMode".
Olivier_G
Post by Olivier_G »
helmut wrote:A
Currently we have:
ColorInfo in [View]
0: Normal
2: Keep always
helmut wrote:B
They are not the same as B:0 = A:1
Olivier
marsh
Post by marsh »
C
ResetColorInfo
0=Reset after current image
1=Reset after current session
2=Do not reset
marsh wrote:C
ResetColorInfo
2=Do not reset
"Reset" is a close related and almost correct word, here, but it's not clear what is reset. So far I think "quit" is best. (There's other terms like Exit, Cancel, but they all have a slightly different meaning, I think).
C
ResetColorInfo
2=Do not reset
For me, ResetColorInfo is better
xnview wrote:For me, ResetColorInfo is better
Please let people discuss a bit more before deciding. ResetColorInfo is a bit better than what we currently have, but as written above it's not clear at all what is reset.
Olivier_G
Post by Olivier_G »
I don't care that much about the wording "Reset"/"Close", but more about the available options.
I see 4 of them:
0. Reset after current image
1. Reset when closing window
2. Reset when quitting XnView
3. Do not reset
(the various suggestions contained 3 of them only and some were different, as I said)
Olivier
GeorgD
Post by GeorgD »
I had to laugh when reading this thread :D
Personally, I just don't want "normal" as description (but normal/default after the description to tell users what's the default setting) and I like the naming "mode" as it tells me it's a mode and not about a dynamic action or whatever :) And now: Let the games continue ;)
