Show colour info not saved…
GeorgD wrote:I had to laugh when reading this thread :D
Thank you for your comment. Your comment put a smile on my face - it's good if there's people who make aware of the situation. :-)
GeorgD wrote:Personally, I just don't want "normal" as description (but normal/default after the description to tell users what's the default setting) and I like the naming "mode" as it tells me it's a mode and not about a dynamic action or whatever
I fully second your above statements. I think my initial suggestion fits well with these. It's a good idea to add an info which the default value is.
Above suggestion with default info:
QuitColorInfoMode <value>
0: Quit mode when closing image (default)
1: Quit mode when exiting XnView
2: Never quit mode automatically
Olivier_G
Post by Olivier_G »
helmut wrote:0: Quit mode when closing image
I find this one slightly misleading, as navigating Previous/Next file implies closing current image... but people may understand 'closing current window' (cf my previous comments about the 4 options and misunderstandings).
Olivier
True, a bit misleading. Perhaps
0: Quit mode when closing window or navigating to another image.
I have seen your suggestion with four options:
0. Reset after current image
1. Reset when closing window
2. Reset when quitting XnView
3. Do not reset
Personally I think that 0 & 1 are the same, but this might be due to my way of using XnView.
foxyshadis
Post by foxyshadis »
As a semantic quibble, I don't agree with the use of "quit" here, where "revert" is closer to the meaning you want. (Reset is also good.) Quit doesn't quite make sense in such a context.
In XnView 1.91 the setting is still named "ColorInfo".
For changing the default behaviour (which is "Quit colour info mode when closing image"), you have to make a change in the settings file "xnview.ini":
1.) Exit all instances of XnView
2.) Edit xnview.ini with a text editor (e.g. NotePad). xnview.ini is located either in the program directory of XnView or in "C:\Documents and settings\<user name>\application data".
3.) Find the string "ColorInfo="
4.) Change it to the value you prefer (see above).
5.) Save your changes made to xnview.ini
