Pierre, thank you very much for "Automatically select new files" feature!
I want other users let know about this great feature - because it's disabled by default (many good features are disabled by default...) and it's not even in "WhatsNew" list (at least I didn't found it)
Examples:
If this feature is on and you rename 10 images in 300 images folder, renamed images are selected (try do the same with 1.70.4)
Also if you move or copy multiple images (with ctrl+x, c, v), they are selected too...
Automatically select new files [just thanks]
Re: Automatically select new files [just thanks]
You're welcomeDreamer wrote:Pierre, thank you very much for "Automatically select new files" feature!
